'96 Engine Oil Capacity Issue
Old Mar 10, 2004 | 09:12 AM
Ron04,02,96,64's Avatar
Ron04,02,96,64
Default '96 Engine Oil Capacity Issue
The 1996 owners manual says:
- 4.0 qts without filter
- 4.5 qts with filter
To my knowledge, ALL Chevy small blocks in the past required AT LEAST 5 qts of engine oil. Is the manual wrong??
To further confuse the issue, when I change the oil and put in just 4.5 qts and check later after its fully drained into the pan, the dipstick always reads
correctly. :(
Old Mar 10, 2004 | 09:16 AM
bogus's Avatar
bogus
Default Re: '96 Engine Oil Capacity Issue (Ron04,02,96,64)
There were issues with the LT1 and oil foaming if you put in all 5 quarts.
Old Mar 10, 2004 | 10:17 AM
MSR's Avatar
MSR
i'm pretty sure the LT4 takes more. mine showed full on the stick when i used about 5.5qts. i've seen a few references on the web to the same, such as:
http://www.grandsportregistry.com/96_specs.htm#SPECS
with the stock pan i used to run 6qts, to help keep it from starving during auto-x.
-michael
Old Mar 10, 2004 | 10:22 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: '96 Engine Oil Capacity Issue (MSR)
5 for me!
Wierd on the 96 tho..... :flag
Old Mar 10, 2004 | 10:47 AM
sinc93's Avatar
sinc93
Default Re: '96 Engine Oil Capacity Issue (VictorRussell'92)
I put in 4.5 with a filter change. It will read a little low at first after refilling the oil. Let it sit overnight and check it again. It will read right on the full mark. I know a lot of places that overfill the engine I guess because it's easier just to dump in the last quart. One Corvette place told me it varied from engine to engine and they have dumped in as high as 6 quarts into an LT1. I politely mentioned that if the internals and pan are all the same, could it be possible that the dipstick installation is the part that varies. That seemed to make them stop and think. I'd rather not risk blowing my seals and just put in what the powertrain engineers say to do.
Old Mar 10, 2004 | 11:21 AM
SouthernSon's Avatar
SouthernSon
Bogus is right. If the oil level interferes with crank throw, it will be whipped into a foam (aerated). If the oil foams, one can loose oil pressure because the pump cannot pump foam. (a very bad thing). :eek:
[Modified by southern_son, 10:22 AM 3/10/2004]
Old Mar 10, 2004 | 01:41 PM
JasonL's Avatar
JasonL
I put 5 qts in my '96 and have never had no foaming issues.
There's really no comparison to earlier SBC because it depends on the oil pan design. e.g. I believe the LT1 F-body takes closer to 6 qts.
Old Mar 10, 2004 | 01:58 PM
TM-Z06's Avatar
TM-Z06
I just changed my oil/filter this past weekend. I added 5 quarts, let it sit a while, checked it, and it was on the low side of the "operating range" on the dip stick. So I added a 1/2 quart more, let it sit, checked it.....perfect.
Old Mar 10, 2004 | 07:53 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I use 4 qts when I change oil and the filter.
To '96 Engine Oil Capacity Issue
