Rear Spring
Old Mar 10, 2004 | 02:59 PM
vstol's Avatar
vstol
Default Rear Spring
I have the 96 rear end setup from a Collectors Edition on my 64 GS. How can I tell what rear spring I have. Are there numbers on the spring which will identify the rate?
Old Mar 10, 2004 | 03:58 PM
bogus's Avatar
bogus
Default Re: Rear Spring (vstol)
there should be a sticker, or, perhaps, something pressed into it.
the most common code is NYR, which is a base spring. I can link you a suspension table later today. It has all the spring rates in Newton meters. I also have a formula to convert them to inch/pds.
