IS your FUEL gauge inactuarate?? fix inside
what i did to replace the sender/float assembly...went to wreckers and found a similiar unit..now this new unit must be diassembled...you want only the carbon contact which is worn and makes blut contact with coil) and the resistance coils Check coils for ressistance similiar to that of the old .they could very a little bit...fit these new components into the old shell using the old float bracket,, depending on skill level it can be done without soldering...reassemble...use some patience and common sense and you will have you fuel gauge working acturately again. :)
