Cold Start Elimination
Old Mar 11, 2004 | 06:08 PM
vetteguy216's Avatar
vetteguy216
Default Cold Start Elimination
If you have installed a SR base manifold but still have the stock TPI up top what do you need to eliminate the coldstart besides the fuel rail plug.
Old Mar 11, 2004 | 06:23 PM
ZylaRace's Avatar
ZylaRace
Default Re: Cold Start Elimination (vetteguy216)
Plug the end of the fuel rail.
Plug the 9th injector hole on the stock intake. But the SR has it's own intake,... so there is nothing to plug there.
There is a module that controls the 9th injector. You can disconnect it if you what. It doesn't effect anything else.
If you only drive in warm climates,... you probably won't need to do much else. But if your doing the SR, you are prolly doing a recal anyway. (You should already have the updated cold start fuel numbers.)
