Accessory belt question on 92 engine swap HELP!!!!!!!
Old Mar 11, 2004 | 07:43 PM
Nuvolari's Avatar
Nuvolari
Default Accessory belt question on 92 engine swap HELP!!!!!!!
Hi All,
I am doing an engine swap on my 92 (originally LT1) vette. I'm installing a carburetted 355ci small block Chevy engine with the one piece rear main seal to match up to my flywheel. My question is how do I run the accessory belts to drive the alternator and power steering pump (I have no AC as this is a race car)? My LT1 had a nice cast aluminum bracket that held all the parts and ran everything off of a serpentine belt. I'm not sure if I should try and use this or go to v-belts all around. I need help here because I am totally in the dark. Any advice would be most appreciated.
Old Mar 12, 2004 | 09:49 AM
Nuvolari's Avatar
Nuvolari
Default Re: Accessory belt question on 92 engine swap HELP!!!!!!! (Nuvolari)
Anyone? Any leads?
Old Mar 12, 2004 | 05:02 PM
Nuvolari's Avatar
Nuvolari
another bump
Old Mar 15, 2004 | 09:40 AM
Nuvolari's Avatar
Nuvolari
Still searching for answers
Old Mar 15, 2004 | 10:35 AM
bogus's Avatar
bogus
I would use the aluminum bracket and get a shorter belt...
Old Mar 15, 2004 | 11:56 AM
FD2BLK's Avatar
FD2BLK
S&P may have what you are lookinjg for. http://www.hotrodlane.com
[Modified by 84LT1, 10:57 AM 3/15/2004]
To Accessory belt question on 92 engine swap HELP!!!!!!!
