Brake Calipers
Old Mar 12, 2004 | 12:30 PM
rsafier's Avatar
rsafier
Default Brake Calipers
Can I switch my 85 to 88+ front non-HD design (can't upgrade to 13" rotor without changing wheels). I'm thinking I might need to replace the front calipers, seem gunked up, and figure might as well get the two-piston design plus the wider pad selection that comes with it.
What is involved in the switch? Do I need a different braket or will it just bolt up. Will they still clear 16" wheels?
Old Mar 12, 2004 | 12:34 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Brake Calipers (rsafier)
Keep in mind that in 88 when they went to the newer 2 piston 12" setup, they also changed the 16" rim design. I don't know if that was to get more clearance or ????
I've never compared a 84-87 caliper to a 88-94 12" set up. I would be interested to know as well.
