383 rod clearance
RACE ON!!!
ps. If your 383ci is gonna be mild then no need to use the H beam. The I beam will do a fine job.
Bruce
[Modified by Bruce, 2:05 PM 3/13/2004]
Original poster:
It's not at all bad to clearance the block. As mentioned, the cam is what needs to be small base circle.
I figure a machine shop will clearance the block for under $100.00 bux. Some have a CNC machine that they put the block into and the computer directs the drill bit to the appropriate locations.
I did my own by hand. I first bought a carbide drill bit for around $15.00. It cuts thru like a hot knife thru butter so go easy.
I then mocked up the crank on main bearings and a rod with bearings on each throw to see where the rod bolt would touch the block and began slowly shaping away:
*note: on my crank there was abit more throw(3.835) than a 383(400) crank, so you don't need as much material removed as my pics show
You can remove the lower soft plugs in the sides of the block to have a better view of the inside water jacket passage than can be seen thru the coolant holes on the deck surface. If you do break thru with the drill bit, the hole can be welded shut.
[Modified by 89 Paul in Cal, 1:49 PM 3/13/2004]
