Compression Check #s, do these sounds about right?
Old Mar 14, 2004 | 04:06 PM
rsafier's Avatar
rsafier
Default Compression Check #s, do these sounds about right?
Just did a compression check while everything was apart. Got 160-165 on all the cylinders. Is this about right for a 85 with 68K miles on it?
Oh some more information, engine has been cold, hasn't run in 4 weeks. And I didn't prop the throttle blades open, just read that you should probably do that, oh well, guess the numbers might be a little lower then if it was wide-open?
[Modified by rsafier, 3:19 PM 3/14/2004]
Old Mar 14, 2004 | 05:33 PM
neat's Avatar
neat
Default Re: Compression Check #s, do these sounds about right? (rsafier)
Sounds real good to me. I think your in great shape.
:hurray:
Old Mar 14, 2004 | 05:50 PM
C4Crazy787's Avatar
C4Crazy787
My LT1 @ 10.5/1 CR runs 195-205psi with 50k miles. :seeya
Old Mar 14, 2004 | 05:53 PM
rsafier's Avatar
rsafier
Default Re: Compression Check #s, do these sounds about right? (C4Crazy787)
okay, wasn't really sure, most people have higher compression ratios then I do. Think the 85 is only 9.0:1.
Old Mar 14, 2004 | 06:10 PM
C4Crazy787's Avatar
C4Crazy787
If that's correct then your right on around 160psi
Old Mar 14, 2004 | 06:24 PM
CFI-EFI's Avatar
CFI-EFI
What you show looks good, but you should really retest with the throttle open. All cylinders within 10% is a fairly universal standard. These numbers don't even come close to the limits. Believe it or not, cam timing has a bigger influence on static compression numbers than compression ratio. My 1984, with 160,000 mile on it, and never been apart, varies between 165 and 175. It also has a 9.0:1 compression ratio.
RACE ON!!!
PS. The numbers will be higher with the throttle open.
To Compression Check #s, do these sounds about right?
