im looking for some opinions on this lowering kit i found from mid america
has anyone tried it? is it worth it? is there a risk of messing up my camber, toe or caster settings? thanks
The longer bolts they give you for the back really weren't long enough on my car. All they did was level the back up with the front. I never put the wedges on since I'd be right back where I was before with the tail sticking up in the air.
To use the front wedges, I'd have to switch the rear spring spacers to the other side of the spring at least.
But that's my car. If your ride doesn't have springs with 120K miles on them, it might respond better to the kit.
Whenever you do ANY modifcation with lowering, you'll have to get your car realigned.
