Smoke Question
Old Mar 15, 2004 | 08:42 AM
CMYC4GO's Avatar
CMYC4GO
Default Smoke Question
I am getting a tiny bit of blue smoke on deceleration, and I can't for the life of me remember the old rule. For smoke, is it RINGS on acceleration and VALVES on deceleration, or the reverse? :confused:
Also, this 85 is belching dark grey/black smoke when I really romp on it, so I know I've got at least 1 bad injector. What is a good replacement set of injectors to go with?
[Modified by White85InOKC, 7:43 AM 3/15/2004]
Old Mar 15, 2004 | 08:56 AM
CMYC4GO's Avatar
CMYC4GO
Default Re: Smoke Question (White85InOKC)
bump
Old Mar 15, 2004 | 10:16 AM
dlmeyers's Avatar
dlmeyers
I would recommend a cylinder leak down test. Your compression ring(s) could have some wear, cylinder bore fair wear and tear taper, reduced tension on the oil control rings, just for starters. If the car doesn't smoke on start up, valve guides and seals may be OK.
Some parts stores may loan the special tools for for the cylinder leak down test.
Let us know.
dlmeyers 90 coupe zf6 3 speed shocks
Old Mar 15, 2004 | 11:09 AM
rick lambert's Avatar
rick lambert
Old rule of thumb-deceleration-rings.Do a compression test.Ford motor sport #24 are some of the injectors guys are using. Good Luck :seeya
Old Mar 15, 2004 | 11:32 AM
J Z06's Avatar
J Z06
I have always heard,
Acceleration: RINGS
De-celeration: VALVE SEALS
:skep: :cheers:
Old Mar 15, 2004 | 12:06 PM
rick lambert
Default Re: Smoke Question (Jay 383)
Valve seals usually show just after starting the car after its sat for awhile, oils leaks past the seals and when you fire it up it smokes-normally not to long though. But do the compression test first-if you get a low reading squirt a little oil in the cylinder and retest-if comp. comes up its bad rings, if no change it's in the valve train :thumbs:
[Modified by rick lambert, 5:10 PM 3/15/2004]
Old Mar 15, 2004 | 01:36 PM
larryfs's Avatar
larryfs
no matter what it is, just keep driving it!!!
what's a little smoke....
Old Mar 15, 2004 | 04:27 PM
JAKE's Avatar
JAKE
Dark grey/black smoke on acceleration is excessive fuel; you're running rich.
The blue smoke is most likely valve stem seals. Deceleration creates high vacuum which sucks in oil from the valve spring area.
Jake
To Smoke Question
