Hollowing out cats
Old Mar 15, 2004 | 09:47 AM
rtracy's Avatar
rtracy
Default Hollowing out cats
If one was to hollow out there cats would the car run alright ? Would you have to do something with the o2 sensor? Thanks, Ray
Old Mar 15, 2004 | 10:20 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Hollowing out cats (rtracy)
Isn't this illegal???? Here in PA
By the way - what year would this be done to?
Old Mar 15, 2004 | 10:21 AM
LD85's Avatar
LD85
Default Re: Hollowing out cats (85vet)
did not bother mine at all, worked fine!
Old Mar 15, 2004 | 10:44 AM
rick lambert's Avatar
rick lambert
Default Re: Hollowing out cats (ld85)
I've done it before-but it is generally illegal. I just took a hammer and small diameter pipe and knocked everything out, cat was plugged, car ran fine. :thumbs:
Old Mar 15, 2004 | 11:15 AM
rtracy's Avatar
rtracy
This would be done to a 95. It has both before and after o2 sensors.
Old Mar 15, 2004 | 11:30 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
It wont hurt the O2 sensors a bit. I just made some J-pipes and removed the CATs. Of course I added the O2 bungs for the sensors. :cheers:
Old Mar 15, 2004 | 11:38 AM
rtracy's Avatar
rtracy
Default Re: Hollowing out cats (VictorRussell'92)
What are o2 bungs?
Old Mar 15, 2004 | 11:52 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
What are o2 bungs?
O2 bungs are what hold the o2 in place. What you screw your O2 sensor into. :yesnod:
Old Mar 16, 2004 | 02:31 AM
madmike's Avatar
madmike
You will get more horsepower. Thats the only difference I saw. I hollowed out the precats. All they were doing is destroying my main cat. I left my main cat in the car to help pass smog. The car runs fine and passes smog :hurray:
Old Mar 16, 2004 | 10:14 AM
rtracy's Avatar
rtracy
Great, thanks Guys!
Old Mar 16, 2004 | 10:39 AM
bac22's Avatar
bac22
If you hollow out the cats without putting a straight pipe inside then the larger area in the cat will decrease flow velocity causing flow stagnation, and decreasing bottom end power. If you cat was fine to begin with they you'll reduce your performance by an hp or 2. The only time hollowing out a cat increases performance is when the original cat was in bad shape to begin with (IE clogged).
Ask any exhaust system guru and they'll this is exactly what they will tell you.
[Modified by bac22, 10:44 AM 3/16/2004]
Old Mar 16, 2004 | 10:45 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Default Re: Hollowing out cats (bac22)
So install J-pipe like I said. And I'm calling :bs on anyone who says removing your CATs properly wont increase HP. :p:
Old Mar 16, 2004 | 11:56 AM
rtracy's Avatar
rtracy
We have visual inspections so I can't just put a pipe in it's place. It has to apear that it is there.
Old Mar 16, 2004 | 12:15 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Well I have heard of people inserting pipes in their cats so you get the apperance of a cat with the straight pipe performance. Probably your best bet. Dont now how to do it tho.
Old Mar 16, 2004 | 12:28 PM
rtracy's Avatar
rtracy
Welders have there benefits, I just might try that.
To Hollowing out cats
