Overheating problem solved?
Old Mar 16, 2004 | 05:05 PM
Metamando's Avatar
Metamando
Default Overheating problem solved?
I just removed the air filter box and the piece it bolts to, and there's a thin rubber shield- sort of piece that looks like it may be blocking airflow. Has it possibly slid down from where it was covering bolt heads, or is it needed there? There IS a cutout in the metal up front that looks like it goes there. Also, am I right in thinking to check between the A?C unit and radiator from underneath? There's a lotta stuff bolted up top. TIA, MM
Old Mar 16, 2004 | 05:17 PM
rick lambert's Avatar
rick lambert
Default Re: Overheating problem solved? (Metamando)
You really need to pull the radiator schroud to look, and it's worth it, my 87 is running 15-20 degrees cooler. Don't know about the other. :D
Old Mar 16, 2004 | 07:39 PM
Metamando's Avatar
Metamando
Default Re: Overheating problem solved? (rick lambert)
:lurk:
To Overheating problem solved?
