From: Sarcasm. Just one of the many services I offer.
C4 Weight Reduction and Speed
I often see posts where people have said their vette was faster than cars with simliar/more horsepower. Is this because of the lighter weight of the vette? How much of a factor is the vette's lighter weight as far as reaching speeds faster, and are their any practical methods of further weigh reduction on a stock vette?
Re: C4 Weight Reduction and Speed (ir0nmaiden420)
would it also help if you had as little gas in your tank as possible when racing? say a gallon of gas weighs 8 pounds, so running 12.5 gallons less than full would reduce the weigh of the car by 100lbs
Indeed, I arrive at the strip with about 1/4-1/3 tank of fuel (~80-100lbs) and no spare nor jack (~40-50lbs).
Actually water is 8lb/gal; gasoline is 6.6lb/gal (according to the NHRA rule book).
My launch weight last Sat. was 3350lbs with 1/4 tank of fuel and myself (155-160lbs); so my Vette weighs ~3,190lbs w/o me inside. Compare that with my '86 IROC-Z that launches (with 1/4 tank of fuel) at close to 3,700lbs.
The IROC-Z builds ~255chp and the Vette ~295chp in good weather. This difference along with the large weight difference accounts for nearly 1sec difference in ET.
You can also install lighter wheels to reduce weight without losing any of the ameneties or handling characteristics. You can install "skinnies" up front to further reduce weight and rolling resistance and remove the front sway bar.
Lowering the car will also help a little as it slightly reduces frontal area (which includes the visible rubber).
Of course softer rear tires, though won't increase trap speed, can help in reducing ET which depends strongly on how hard you can launch.
The easiest weight reduction mods are as follows,
Get rid of the spare tire, the spare tire carrier and jack.
Get rid of mufflers and go with muffler elims.
Those two probably take off a good 100-200lbs. :cheers:
Well the ultimate weight-loss comes from removing accessories in the interior and then changing the hood to carbon fiber.
But going to CF hood costs about $1700, and that doesnt include painting.
Or losing weight from your gut.
Most of the suppliers of C4 carbon fiber hoods outright lie about the weight savings potential of changing to a carbon fiber hood. The typical phrasing is such as "50-75 lbs savings off the front of your car." This is pure bs and deception. The stock replacement style carbon hoods are 28-35 lbs. If you email the carbon hood retailers and ask them what a stock hood weighs, they will lie to you and tell you 95-100 lbs. I just weighed my stock hood ... It only weighs 62 lbs. lets see 62-35=27 lbs actual savings. And the quality and fit of these hoods is not in the same league as a stock hood, so it will cost you big big $ to have one installed, fitted, and painted.
I don't ever race with less than half a tank, if I do, I sometimes bog off the line.
My race weight last year with stock wheels and 3/4 tank was 3434, this year I have the Weld wheels, and now a Corsa which weighs 7 lbs less(whoa!), no spare or jack, no front swaybar and I took all the crap I was carrying in the hatch.
Some of the underhood stuff can go as well i reduced 50lbs so far with my 84 corvette by replacing the serpentine belt with a 70.5 in. belt and deleting the smog pump and ac compressor and condenssor. I also have gotten rid of my mufflers with a cheap pair of deletes from corvette central and i have true duel with no converter but my state is a little less strict on emissions. As far as the spare the jack and the spares plastic holder i have pulled all of the brackets and all right out!
