Aside from the Bose not working,I've found a couple of other problems.
I have the automatic climate control. Everything works great until you switch to heat. It does everything right except blow heat. Vacuum Leak???A/c is fine,fan works,but no heat.
Cruise control won't work and
the "Service Ride Control Light" is on.
More about the Bose.Tape runs but no sound.When you try to insert a CD it sounds like a head clicking very fast (Typewriter comes to mind.)Nothing on the radio,
and I get static and poping from the left rear speaker only. No other sound.
That about covers it for now.LOL
Thanks for any help.
Tinman
[Modified by Tinman22, 2:32 AM 3/18/2004] [IMG][/IMG]
If there's no heat but the vents are switching over, suspect a plugged core. Try to flush it by removing the hoses and running some water through it or if you have a compressor you can try to blow some air through it - just watch the pressure so you don't blow a hole in it.
[suspect a plugged core. Try to flush it by removing the hoses and running some water through it ]
I agree, Flushing mine with a garden hose cured it for me.
Good Luck! :smash: :flag
