Sorry this isn't more specific, but the box is on the firewall on Dr. side. I was told it should be silver, coz there were problems with the black one......What is it, and would pep boys carry it?...TIA.....oh sorry, 88 coupe, L-98 engine
More specific would be good but the only "box" that I know started out black and became silver was the ECM...that's your main computer for the engine. Engine Control Module.
If that's what you're talking about, there will be "bunch" of wires...4 bundles running into it.
Your friend is wrong. I believe they changed configuration and color in 93 when they went from OBD1 to OBDII. There is nothing wrong with the black ones anymore than the silver ones...two different computers.
The change to the computers happened very late in 93. I have a late 93 (but not late enough for the new computer). The silver ECM's did not have an eprom, to be reprogrammed, they have to be flashed. OBDI was used through 1995.
If its an 88, the ECM will be in the pass dash, not in the engine bay. A pic would be good at this point. Unless its different in the vert to the coupe :confused:
