installing rr's do i really need hardened pushrods?
Old Mar 19, 2004 | 11:36 AM
mos90's Avatar
mos90
Default installing rr's do i really need hardened pushrods?
im putting comp cam pro magnum rr's in my 91 l98 and i have new studs and guideplates. do i really need new pushrods. i know the stock length is ok to use 7.2" but i heard that the stock pushrods are already hardened. what do you recommend?
Old Mar 19, 2004 | 01:04 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: installing rr's do i really need hardened pushrods? (mos90)
Are the rocker arms self-aligning? Are the guide plates the factory do nothings? Or aftermarket "real" guide plates? The purpose of hardened push rods is to prevent them from wearing out against effective guide plates. Self-aligning rocker arms should not be used with guide plates. IF you have non self-aligning rockers, and true guide plates, you need hardened push rods. I hope that since you went to the expense of new studs, that you got the 7/16ths" set up. Good luck, and...
RACE ON!!!
Old Mar 19, 2004 | 01:09 PM
h rocks's Avatar
h rocks
Default Re: installing rr's do i really need hardened pushrods? (CFI-EFI)
:iagree: If you don't want to spend the $125 on Comp or another name brand, I think Summit has a "house" brand that's considerably cheaper.
Old Mar 19, 2004 | 01:13 PM
mos90's Avatar
mos90
Default Re: installing rr's do i really need hardened pushrods? (h rocks)
they are non- self aligning. and are comp cam "real" guide plates. would it be easier if i just put self- aligning rr's on.
Old Mar 19, 2004 | 02:20 PM
CFI-EFI's Avatar
CFI-EFI
That combo requires hardened push rods. Easier? I guess that depends on how much "work", you feel is involved in changing the push rods.
RACE ON!!!
Old Mar 19, 2004 | 02:51 PM
mos90's Avatar
mos90
i dont mean easier i mean more cost effective without sacrificing stability.
Old Mar 19, 2004 | 03:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The non self-alinging CC ProMagnums are about $260 and (I think) the self-aligning ProMagnums are over $300. So get the cost of hardened guide plates & push rods and do the math.
The reason I went to non self-aligning ProMagnums is that I wanted the sturdier 7/16" studs. Since you have to pull the studs anyway to remove or swap the stock non-hardened guide plates you might as well upgrade to new ARP 7/16" studs.
Don't foreget to get some light assembly lube and put a little on each end of the new push rods, on the sides of the guide plates and on top of the valve stem tips. Motor oil is fine to lube the RR rollers & tips.
BTW, CC lists the hardened push rod for out SBC as P/N 7808-16, 5/16" x 7.195" High Energy Pushrods.
[Modified by 65Z01, 3:20 PM 3/19/2004]
Old Mar 19, 2004 | 05:14 PM
mos90's Avatar
mos90
Default Re: installing rr's do i really need hardened pushrods? (65Z01)
i bought the flat guide plates, are those the right ones. and those high enegy push rods are good for guide plate use(say cc) and are only $35.00. thanks
Old Mar 19, 2004 | 07:05 PM
JackDidley's Avatar
JackDidley
Be sure you have pushrods for the factory roller cam. Normal SBC flat tappet pushrods are longer. :thumbs:
To installing rr's do i really need hardened pushrods?
