Any tips for getting the opti back on???
Old Mar 20, 2004 | 11:34 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Any tips for getting the opti back on???
I am positive the cam pin is lined up with the hole.. but I push and push, and those little o-rings dont want to go in!!! Any tips??
Old Mar 20, 2004 | 02:53 PM
JasonL's Avatar
JasonL
Default Re: Any tips for getting the opti back on??? (MarkLT1)
Non-vented or vented?
Try lubing the o-rings w/ a drop of engine oil. If it's a vented opti... give it a hard shove.
Old Mar 20, 2004 | 03:01 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Only one way they go on, use some oil like already mentioned, and make sure nothing is interfering.....
:cheers:
Old Mar 20, 2004 | 03:09 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Any tips for getting the opti back on??? (edsalinas)
Check the hole and make sure chunks of the old one aren't in there.
... speaking from experience :rolleyes:
Old Mar 20, 2004 | 05:28 PM
John Row's Avatar
John Row
If you still have the 92 cam, there is 1 tooth in the splined shaft that lines up the rotor with the cam. It slips on when perfectly aligned. Look for the white dot on the shaft.
I've always had more luck putting the shaft on the cam then setting the opti in place.
It just take patients.
Old Mar 20, 2004 | 06:43 PM
Cherry6speed's Avatar
Cherry6speed
I just installed mine the other day, I know how you feel. I positioned the drive pin mark to 12:00 on the motor first, then pulled the pin out of the motor and oriented the opti to 12:00 as well. The problem is; when you twist the opti, the pin moves the distributor drive pin and it won't line up. Line-em both up to 12:00 and don't twist it and she will pop right on. I guarantee it!
Good luck :cheers:
Old Mar 20, 2004 | 07:00 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: Any tips for getting the opti back on??? (RUBYREDVETTECARD)
Thanks for all the tips everyone..
I pushed until I thought I couldnt push any more.. and POP.. it went on.. just have to button everything else up tomorrow.. :) :cheers:
To Any tips for getting the opti back on???
