Console removal help 88 Coupe
Old Mar 20, 2004 | 07:42 PM
Duf's Avatar
Duf
Default Console removal help 88 Coupe
I have a replacement mirror joystick that I need to install. The only way it appears to be removeable is if I pull the console up. I have removed every screw I can find but it still seems rather secure. Can anyone offer pointers on this so I don't damage anything? Thanks!! :D
Old Mar 20, 2004 | 08:59 PM
Stingraynut's Avatar
Stingraynut
Default Re: Console removal help 88 Coupe (Duf)
Hi, I have an 88 and there are two bolts at the front under the front facia and two screws at the rear, in the centre glove box.
Err.....this is from memory but I'm fairly certain.
S'nut
Old Mar 20, 2004 | 09:11 PM
86Pacecar's Avatar
86Pacecar
There ar 4 screws in the center glove box that are hidden under removeable tabs, it's probably what you haven't got yet. :thumbs:
Old Mar 20, 2004 | 09:31 PM
89vert's Avatar
89vert
Just got my manual out. There are six screws holding it in. 2 by the heater control, 2 by the window switches and 2 inside the the console cover. I believe 1 holds the tab that the console covers locks on to. Hope this helps.
Old Mar 20, 2004 | 10:57 PM
Stingraynut
Default Re: Console removal help 88 Coupe (89vert)
Oh yes, I forgot the two visible screws near the window switches. I just checked and I definitely only have 2 screws in the glove box, both visible - I don't have any 'removeable tabs', what do they look like 86 Pacecar ?
S'nut
Old Mar 21, 2004 | 06:58 PM
Duf's Avatar
Duf
Well I got it out but never did find those 2 screws in the console area OR around the power windows switches. Sure they are there on 88's? :confused: Anyway I actually had some success this weekend. I successfully replaced the power mirror joystick, one of the power window switches and the rear hatch solenoid. Everything worked! Amazing, but true.
Tons more to do but those little battles help make it seem worthwhile. :cheers:
Old Mar 21, 2004 | 08:41 PM
Stingraynut
Well, main thing is that you got the job done, but it is strange, my 88 has 6 screws all as mentioned. The ones on the top of the console are 1" behind the power window switches.
:cheers:
S'nut
To Console removal help 88 Coupe
