84 Driveshaft ujoint replacement
Old Mar 21, 2004 | 11:56 PM
scorp508's Avatar
scorp508
Default Re: 84 Driveshaft ujoint replacement (edsalinas)
The beam doesn't HAVE to come out, but its makes it worlds easier. You can otherwise unbolt it and whack it to the passenger side to make some more room.
Old Mar 22, 2004 | 06:00 AM
Brimis's Avatar
Brimis
Default 84 Driveshaft ujoint replacement
I just the Helms manual regarding the replacement of the driveshaft ujoints. Does the entire exhaust system actually need to be removed? I removed the cat to the mufflers. I can see the driveshaft pretty well. What about the support beam, does it need to come out?
Old Mar 22, 2004 | 06:49 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: 84 Driveshaft ujoint replacement (Brimis)
Yes the support beam should come out. There's not much room to get the driveshaft out unless you do. At least for me, it seems easier that way.
To 84 Driveshaft ujoint replacement
