ARP 7/16" rocker studs p/n
Old Mar 22, 2004 | 07:32 AM
C490Vette's Avatar
C490Vette
Default ARP 7/16" rocker studs p/n
Does anyone know the Summit part number for the ARP 7/16" rocker studs that would go with the following parts
-Comp Cams #1305-16, 1.6:1 ProMagnum RRs for 7/16" studs
-Comp Cams #4800-8, hardened raised guide plates
-Comp Cams #7808-16, hardened push rods for 1997 and newer SBC
I looked on Summit and it seems they have a few different 7/16" rocker studs and I dont want to get the wrong one. Thanx!
Old Mar 22, 2004 | 07:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: ARP 7/16" rocker studs p/n (C490Vette)
Summit offers two sets or ARP rocker arm studs:
HP Series: ARP-134-7103, small Chevy & Pontiac V8, 7/16" at $29.88
Pro Series: ARP-234-7202, small Chevy & Pontiac V8, 7/16" at $54.95
The HP Series are made of heat-treated 8740 Chromaloy rated at 170,000 tensile strength; the Pro Series are made from premium grade Chromaloy rated at 190,000 tensile strength.
I can't recall which I purchased but think if you are not going to extreme valve lift the HP Series should be fine.
Old Mar 22, 2004 | 09:31 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: ARP 7/16" rocker studs p/n (65Z01)
I have a set of them if your interested. My new heads came with a set, so I have these ones from my 190AFRs :cheers: 25 beans they are yours. :cheers:
To ARP 7/16" rocker studs p/n
