RIMS
Old Mar 22, 2004 | 07:53 AM
JohnyH's Avatar
JohnyH
Default RIMS
HAVE back tires are 315 x 35 x 17
1988 (z51,z52)
front & rear 17"x9.5" 56mm (7.4" backspacing)
Goodyear Eagle ZR, P275/40ZR-17
WILL these fit without rubbing
1990 (zr1)
front 17"x9.5" 56mm (7.4" backspacing)
Goodyear Gatorbacks, P275/40ZR-17
rear 17"x11" 36mm (7.93" backspacing)
Goodyear Gatorbacks, P315/35ZR-17
Old Mar 22, 2004 | 03:53 PM
JohnyH's Avatar
JohnyH
Default Re: RIMS (JohnyH)
Lots of lookers ANYbody have an answer????
Will the rims fit and if they do will they stick out?????
Old Mar 22, 2004 | 04:13 PM
TA's Avatar
TA
The 17x11, 38mm offset is the ZR-1 offset. They will stick out on a non-Zr1 considerably, probably about an inch or so.
What you want is the 17x11s with the 50mm offset (GS offset). They will probably stick out a tad, but only about .25" or so.
Here's a picture of the GS offset on the back of mine
[Modified by TA, 4:15 PM 3/22/2004]
Old Mar 22, 2004 | 04:15 PM
Zix's Avatar
Zix
Default Re: RIMS (TA)
I had ZR-1 offset rims on my 96, they do stick out, but certainly not that far. Maybe 1/4-3/8". I didn't mind because I bought a set of GS fender flares with them.
Old Mar 22, 2004 | 04:45 PM
JohnyH's Avatar
JohnyH
Default Re: RIMS (Zix)
I Have the stock rims on the car now with 315 x 35 and 17 inch rims. They stick out now a wee bit maybe an inch, probably less. I'm guessing with the 11 inch rims and the same tire they will not stick out any further? What sticks out now is the tire. and not so much the rim. Is there concern for something rubbing in the back?
Old Mar 24, 2004 | 11:56 AM
JohnyH's Avatar
JohnyH
After considerable research it seems that I do want the GS rims
rear 17"x11" 50mm (7.93" backspacing)
Anyone got SOME?
These will go on an 88 red Rodster, black or chrome?
To RIMS
