Heed the WARNING
When I was putting on my balancer, which is marked with its OWN timing marks, which allowed me use of a single pointer I compared the timing numbers on the balancer to that of the generic pointer I had laying around my garage. To my surprise there was a HUGE difference in timing layout/spacing. Here is a picture of the difference:
As you can see the balancer reports back a lesser span 10* where the generic tab is not even to 8*!!!
THIS IS A HUGE PROBLEM if your using one of these generic timing tabs and trying to get your base timing set off it.
I know many of you guys have aftermarket motors like the ZZ4 shortblock or upgraded your motors and may have put one of these tabs on your setup.
Its really worth taking a look at.
This timing tab was suppose to be for this size balancer also.
Just thought I would again point this out to you all for it may help some people that are having knock counts with base set at 6* and do not know why.
Moral of the story is 6* on your timing tab might not be 6* at all. More like 8-9* :crazy:
Yes the stock ones only have 1 mark, and this pointer was suppose to work on this size balancer, so the timing marks should be equal :cheers:
RACE ON!!!
If the base timing is set at 6* and it recorded in the tune as such, it should indicate with the ECS plugged it the same timing as the scanner reports out on the balancer timing marks. ie 25* at idle. :cheers:
