Vacuum Lines
Old Mar 22, 2004 | 01:04 PM
86Coupe's Avatar
86Coupe
Default Vacuum Lines
I want to replace all the vacuum lines on my '86 Coupe, but can't seem to find any parts at the normal places. Is there a place, dealer or otherwise, that would sell a complete OEM vacuum line kit? Or am I better off just replacing all the lines by cutting them myself, and replacing all that britle plastic with new rubber lines, using 'T's where needed?
Thanks in advance
Old Mar 22, 2004 | 01:53 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Default Re: Vacuum Lines (86Coupe)
Big Red, I can't help you but I will be following this post closely to see if such a kit exists...Good Luck :cheers:
Old Mar 22, 2004 | 02:37 PM
vetteseniorcit's Avatar
vetteseniorcit
The plastic vacuum tubing has been discontinued for some time by Mr Greedwrench. I replaced all of it with rubber tubing on my 87 and suffered no problems. No one makes any "kits" that I am aware of.
Old Mar 22, 2004 | 07:06 PM
Gregory VanLare's Avatar
Gregory VanLare
You can still pick up one of the two plastic lines from GM, the other you can get from a later model, (this one attaches the to the fuel pressure regulator) and it has an extra connection (at least one more than my 85) which I just capped off. I took the end connector off of the original one and put it on the modified replacement in order to have the lines go in the correct direction. I've had no problems.
Old Mar 25, 2004 | 06:23 PM
stock86vette's Avatar
stock86vette
Default Re: Vacuum Lines (Gregory VanLare)
I just orderd mine from a local GM dealer, some of the lines are still avialible some are not.... The long line that "V"s and connects to the fuel pressure reg is still avil, I have it in my hand, just rec it today $14.00 plus $8.43 s&h. I also needed the egr valve harness and hoses unfortunally those are NLA.... Take a look at my past posts for the GM part numbers :thumbs: :cheers:
Old Mar 25, 2004 | 07:24 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Vacuum Lines (stock86vette)
My plastic lines were broken in a few places... I replaced all the rubber lines, and patched up the plastic ones by cutting them and sticking rubber lines and tees where necessary. All better. :cheers:
To Vacuum Lines
