Radio Display problems
Old Mar 22, 2004 | 03:49 PM
Sleper's Avatar
Sleper
Default Radio Display problems
My display in my radio (delco bose in my 88) will not shut off after the key is removed. How do I fix this so it does turn off? Problem is that with the display staying on it is killing my battery. It did work in the past so something or some part is failing. Any and all help would be greatly apprediated. Thanks in advance
Old Mar 22, 2004 | 05:32 PM
85blkZ51's Avatar
85blkZ51
Default Re: Radio Display problems (Sleper)
You can call some electronics shops in your area and ask if they work on G.M. radios. Ecklers has a rebuild service,price is somewhere around $150.Until then you might have to add a cut-off switch to the radio.
