Brakes
Old Mar 24, 2004 | 08:22 AM
drezma's Avatar
drezma
Default Brakes
Replaced Master cylinder (new Delco) because brake pedal was going to floor and brake light was coming on. Worked fine for one day. Now same thing happening. 94 Convertible. any ideas. Thanks
Old Mar 24, 2004 | 08:26 AM
bogus's Avatar
bogus
Default Re: Brakes (drezma)
you have a leak... check all your brake lines and calipers. Something is badly amiss.
You might have to add dye to find it... but don't drive it until you do.
Old Mar 24, 2004 | 09:13 AM
QuikZilver's Avatar
QuikZilver
Default Re: Brakes (bogus)
:iagree:
Check your hoses and calipers for leaks.
:smash:
Old Mar 24, 2004 | 07:57 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
Can you see fluid leaking at the wheels( will likely be in back, by the calipers)
Any fluid on the ground, under the car?
Any fluid missing from the Master cylinder reservoirs? ( I should have started here :rolleyes: )
If fluid is fine, and the pedal still goes to the floor, you may have gotten a bad MC.
Are you sure it was new and not a reman?
:seeya
:steering:
Old Mar 24, 2004 | 08:21 PM
guywade's Avatar
guywade
got air in the lines ! does it pump up, ??
Old Mar 25, 2004 | 04:11 AM
drezma's Avatar
drezma
Default Re: Brakes (guywade)
No leakage - Brake does pump up - then progressively goes back to floor - it was a new Delco factory Master cylinder. Could it possibly be my Booster?Thanks to all who have answered.
To Brakes
