Tach filter again
Old Mar 25, 2004 | 09:53 PM
shepsvettes's Avatar
shepsvettes
Default Tach filter again
Hi looking for the tach filter on my 93 LT1 found a little square box with tape around it has three wires located just below the coil connection, Is this the tach filter? If not where should I look for it at/ Thanks :confused: :confused:
Old Mar 25, 2004 | 10:05 PM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Tach filter again (shepsvettes)
yes, that is the tach filter. Mine is located towards the top of the engine block, passenger side of the car and has a black and white wire (two blacks I think) coming out of it.
If memory serves me correct, the white wire is cut because there used to be a MSD ignition in it. MSD isnt hooked up but the tach still works with the cut wire. I've still yet to figure out what this filter really does :confused:
Old Mar 25, 2004 | 10:13 PM
shepsvettes
To use a MSD unit do What wires do I need to connect? :confused:
Old Mar 25, 2004 | 10:17 PM
vetteweiser
Cruise-In V Veteran
there was a set of wires that came out of my msd, that plugged into wires that came off the ignition coil (i believe this to be the case, its been a year since I played with it) or the MSD plugged into the ignition coil, I really cant remember. The tach wire was just cut, and not hooked up to anything. I thought I had a picture of this somewhere on my hard drive but cant find it :banghead:
To Tach filter again
