Hot cam tuning
Old Mar 27, 2004 | 04:15 PM
Cherry6speed's Avatar
Cherry6speed
Default Hot cam tuning
I finally got all the idle bugs worked out and the comp cam pro magnums adjusted down (decided it was easier to adjust them with the engine running, messy but effective) and the computer aparrantly went into learn mode because the idle gradually smoothed out. My situation now, is the final tuning, she idles rich and at cruise speed it lopes a little. I am wondering where to go from here. The idle is rock solid @ 900 (Auto) and sounds mean, real mean. The cam really opens up around 3000 rpm (unlike stock) and it shifts @ 5500 which seems like it is too soon, considering how hard this puppy is pulling! Will a chip re-burn correct this shift and/or rich idle? I am using a hypertech thermomaster2 with 160 degree stadt. Any suggestions or comments are welcome. Heck, I am on the learning curve here! I want to max out this set-up. Oh yeah, I believe a 3.73 gear change would help too. Your thoughts? I only have the 1.6 RR's, ported intake, lt-4 cam.
:auto:
Old Mar 28, 2004 | 09:27 AM
93 ragtop's Avatar
93 ragtop
Default Re: Hot cam tuning (RUBYREDVETTECARD)
Well I will answer 1 of your questions. The WOT shift is controlled by the transmission govenor on 93 and earlier. 94 and up are by the computer. I got ski-down-it to reprogram my chip.
Old Mar 28, 2004 | 09:31 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
:lurk:
Old Mar 28, 2004 | 10:58 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
With the hot cam you are definitely going to need a chip reburn..
The chip reburn will fix the rich idle, spark advance, overall fuel maps (at various RPMs) among other things.. Make sure you have an experienced tuner do your work for you (sounds like Ski-down-it is the guy to go to around here.. :) have heard good things about him..).
-Mark
Old Mar 28, 2004 | 03:11 PM
Cherry6speed
Default Re: Hot cam tuning (MarkLT1)
Thats good news, I would definately like to fine tune this set-up. If anyone is wondering about the hot cam pulling strong, forget about it. It pulls hard and sounds even better. Not sure if it what some racers would like, but for a car that drives on the street on weekends it's just perfect. :hurray:
Old Mar 28, 2004 | 05:49 PM
crheinish's Avatar
crheinish
Does your car have a PCM or ECM? I believe 93 was a split year meaning you may have an electronic shift trans. Either way shift manuely @ 6K and get your car programmed by SKI and all will be well. :thumbs:
Old Mar 28, 2004 | 06:49 PM
Nathan Plemons's Avatar
Nathan Plemons
5500 RPM's is certainly too low for the Hot Cam, it'll pull hard to 6500. Get the shift points worked out and you'll enjoy it even more.
Old Mar 28, 2004 | 08:36 PM
JAKE's Avatar
JAKE
Default Re: Hot cam tuning (93 ragtop)
What are the Hot Cam specs again.
Advertised Duration; duration at .050, LSA and valve lifts.
I had those numbers but can't find them now.
Thanks,
Jake
Old Mar 28, 2004 | 08:46 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: Hot cam tuning (JAKE)
Thanks,
Jake
Here ya go... http://www.superchevyperformance.com...s/12480002.asp
:seeya
Old Mar 28, 2004 | 08:59 PM
Nathan Plemons
Thanks,
Jake
218/228 .525/.525 with 1.6 rockers. 112 LSA
Old Mar 28, 2004 | 09:17 PM
JAKE's Avatar
JAKE
Default Re: Hot cam tuning (Nathan Plemons)
Thanks,
Jake
Thanks.
I found another post that gives the valve lift at .525 across with 1.5 rockers, not 1.6. Which is correct?
Jake
Old Mar 28, 2004 | 09:24 PM
C4Crazy787's Avatar
C4Crazy787
Thanks,
Jake
Thanks.
Jake
1.5 rocker lift is .492 check my link posted above.
Old Mar 29, 2004 | 04:07 AM
93 ragtop's Avatar
93 ragtop
Default Re: Hot cam tuning (crheinish)
All 93 vettes were ECM controlled. But if you want to check your car for sure, check to see if it has a TV cable going from the trans up to the ASR control.
To Hot cam tuning
