Help adjusting driver side window....
Old Mar 27, 2004 | 08:45 PM
madquake's Avatar
madquake
Default Help adjusting driver side window....
My window when rolls up seems it rolls a bit too high and crooked.... catchin the upper trim and not closing properly ... What a PITA !!!
Is there a trick to adjusting this thing so it closes evenly with out me having to bring the window down slightly in order to compensate ??
tricks please ... tricks is what I need!!
Thanks Mark A.
[Modified by madquake, 8:46 PM 3/27/2004]
Old Mar 27, 2004 | 11:02 PM
bogus's Avatar
bogus
Default Re: Help adjusting driver side window.... (madquake)
well.. you need to remove the door panel... and the sound shield.
the rest gets into a black art... I don't have all the answers here, its all done by feel.
there are bolts across the top of the door that hold the window pads in place, those will need to be loosened. You will need to check the catch pins - one at the front, one at the back. Also, you will need to check the mounting of the glass to the regulator. Finally, there are 2 bolts top, 2 bottom, that hold the regulator in place.
As I said, off the wall stuff.
Old Mar 28, 2004 | 12:10 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
I have a tech tip that works for window adjustments... email me and i'll send it to you...
Old Mar 28, 2004 | 09:55 AM
madquake's Avatar
madquake
Default Re: Help adjusting driver side window.... (vinnies87)
Thanks thusfar ... my mail is madquake@bellsouth.net
for the tip offered.
Mark A.
Old Mar 29, 2004 | 02:24 PM
madquake's Avatar
madquake
waiting on ya bro.... :)
To Help adjusting driver side window....
