My 95 has adjustable suspension and the passenger side front shock had been seeping oil. The oil caused the upper shock mounting grommet to detiorate. Over this winter a puddle of oil has formed under the shock. Where is the best place to get a replacement shock and grommet? Thanks alot. Ben.
If you have the Bilsteins, you can remove the shock and send it to them to rebuild. Think they charge about $75 - 80 per for the rebuild...
If you're looking to replace, look through the archives here on the Forum - VanSteel was running a special recently. Give Dan a call and he'll help you out.
