84 Headlight Gear Replacement
Old Mar 29, 2004 | 10:02 AM
84 Cherry's Avatar
84 Cherry
Default 84 Headlight Gear Replacement
I finally got some time to pull the housings and motors from the car and what a pain in the a**! You have to completly dis-assemble the entire headlight housing to get the motor off of the housing. The side that was not working was fine except for a part of the gear that is at the staring and stoping point. The shaft had worn down the gear so much that it couldn't get a grip on the teeth. I am waiting for the new ones from Ecklers so that I can put them back together. I am also putting in new headlights to replace the sealed beams. Has anyone done that before? I am assuming that is should be a snap but I am not sure.
