Intake going back on... Suggestions
Old Mar 29, 2004 | 02:24 PM
PUREC4's Avatar
PUREC4
Default Intake going back on... Suggestions
Ok....were polished now and look'n good. Need advise, which thread lock is best for the intake runner bolts and TB in aluminum. Don't want them working loose again. Also the frisbee is the thin style with the heavy outer rim. Remove it? and if so can I reuse the original bolts? :confused:
Coolant bypass done. thanks all :thumbs: :seeya
Old Mar 29, 2004 | 02:57 PM
bogus's Avatar
bogus
Default Re: Intake going back on... Suggestions (PUREC4)
I have read where if you use standard hex head bolts on the intake, it is better. namely, because you can now retighten them with a conventional wrench, instead of a torx, which won't fit!
As for loctite... I donno... anything for engines would have to be ok.
scofolo's Avatar
scofolo
I just removed my frisbee last week and reused the same bolts and added lock washers.
[Modified by scofolo, 1:58 PM 3/29/2004]
Old Mar 29, 2004 | 03:21 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
You may already have this, but if you don't.................
https://www.corvetteforum.com/techti...=266&TopicID=5
Good luck.
Old Mar 29, 2004 | 03:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I wouldn't use thread lock on your runner bolts.
Yes, toss your "frisbee"; the weight is in rim so has the same rotary inertia as the original style. You will need lock washers to maintain bolt depth. I did use thread lock on these bolts though.
Old Mar 29, 2004 | 03:44 PM
JAKE's Avatar
JAKE
Use anti-seize on the threads of the bolts. Any and every bolt or threaded fastener which screws into aluminum should have anti-seize on them, including the spark plugs.
Don't use lock-tite because you may need to remove the bolts sometime down the road. Just torque them to spec and after a few hours or so, recheck the bolts to make sure that the torque is holding.
Jake
To Intake going back on... Suggestions
