Oil Pan Stud Location
Old Mar 30, 2004 | 11:20 AM
tred95's Avatar
tred95
Default Oil Pan Stud Location
In my on-going episode to correct my oil pan leak I am puzzled why there is only one stud on the front side of the pan. The other side is a bolt. I looked it up on the micro-fiche and sure enough it only shows one stud, but on the opposite side to mine.
Can anyone who has changed their pan gasket tell me which side this stud is on, and when you remove the nut does the stud come with it? Isn't the stud supposed to stay in the block if for nothing else but to help with location?
As always thanks for any help.
Pete
[Modified by tred95, 11:21 AM 3/30/2004]
Old Mar 30, 2004 | 12:16 PM
ZZZASY's Avatar
ZZZASY
Default Re: Oil Pan Stud Location (tred95)
On my '96, the studs are on the rear seal housing and I believe there were two studs on mine. Since you are only doing gasket, you will not need to remove the housing.
ZZZASY
'96 LT4
Old Mar 30, 2004 | 12:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, the stud is supposed to stay in. I think it goes on the drivers side, I'll look at mine this evening and let you know for sure.
Old Mar 30, 2004 | 06:03 PM
Corvette Kid
Default Re: Oil Pan Stud Location (Corvette Kid NC)
Shoot, I guess mine came out when I took it apart too. But I'm still 90% sure it goes on the left. Anyone?
Old Mar 30, 2004 | 06:16 PM
MSR's Avatar
MSR
the 2 studs with nuts are in the back two pan holes. up front they're both bolts, but one has a stud on its head. i think this is to hold coolant line brackets in place on some LTx engines (impalas or firebirds?) that have the oil/coolant heat exchangers.
-michael
Old Mar 30, 2004 | 08:01 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I used a Canton oil pan stud kit, so all of them have studs now. :thumbs:
Old Mar 30, 2004 | 09:54 PM
tred95's Avatar
tred95
Hey...Ram that looks like a very good idea. Who handles that stud kit? Looks like I'll be doing a little more work with the oil pan.
Thanks guys for the explanations on the front bolt/stud.
CF rocks!
Pete
Old Mar 30, 2004 | 10:16 PM
Cherry6speed's Avatar
Cherry6speed
My pan stud came off like a bolt. I re-installed it on the passenger side front. I am not sure if that was correct. Let me know what you find and if I need to change mine around. It didn't look like it mattered to me. :troll
Old Mar 30, 2004 | 11:33 PM
Ramrod92's Avatar
Ramrod92
http://www.cantonracingproducts.com/...l_pan_acc.html $10 + shipping. part #22-300 SBC, AMC Oil Pan Stud Kit. I's using it with on fo their pans. Cann't see them well here, but they're on it. :steering:
Old Mar 31, 2004 | 07:53 AM
Strick's Avatar
Strick
Just for your info, my 92 service manual shows a total of 2 studs used. One on either side of the most rear part of the oil pan. :chevy
To Oil Pan Stud Location
