Wheel Stud Bolt Question?
Old Mar 30, 2004 | 11:42 PM
CG77VETTE's Avatar
CG77VETTE
Default Wheel Stud Bolt Question?
Is it possible to press out a broken rear stud bolt on an '86 without removing the emergency brake shoe assembly? I'm trying to figure out a spot that I can do this but I can't seem to find the room I need. Thanks for any help.
Old Mar 30, 2004 | 11:58 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Re: Wheel Stud Bolt Question? (CG77VETTE)
Cut the stud down with a hacksaw. Then punch out the remainder... Next step is pulling the new stud through.
Good Luck! -JRC- :thumbs:
Old Mar 31, 2004 | 05:40 PM
C10 JDR's Avatar
C10 JDR
Definitely possible on an '89, cos I replaced all mine with longer studs. Theres room somewhere round there.
Old Apr 1, 2004 | 11:44 AM
gcrouse's Avatar
gcrouse
You should be able to rotate the spindle to a point where the stud can come out the back. Then give it 2-3 whacks with a 3lb hammer and it's out. Pull the new one in with a lug nut and some stacked washers.
Old Apr 7, 2004 | 03:52 PM
Red ZEE06's Avatar
Red ZEE06
Default Re: Wheel Stud Bolt Question? (gcrouse)
This is the way to do it! WE REPLACED ALL THE STUDS WITH 1" LONGER CHROM MOLY STUDS FROM DOUG RIPPIE MOTORSPORTS. iT'S QUITE EASY TO DO!
To Wheel Stud Bolt Question?
