Need help with mounting rear calipers
Old Apr 1, 2004 | 04:11 PM
CaliforniaVette's Avatar
CaliforniaVette
Default Need help with mounting rear calipers
hey im trying to mount my rear calipers so i can finish up my project. I know how it mounts but the plate for the inboard pad is out to far so i cant slip my caliper on the Rotor. Do i just take a C-Clamp and push it in? The Parking Brake is off when im trying to do this. Thanks for you help
Old Apr 1, 2004 | 06:07 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Need help with mounting rear calipers (CaliforniaVette)
Buy one of those tool at Pepboy or autozone, it has a knop to turn at one end and a flat round piece at the other end and a plate attach to the shaft. Use the old pad to cover the caliper piston put the flat piece on the back of the old pad, the plate against the inside of the caliper, turn the knop to squeez the piston in. You'll get the idea when you see the tool.
Old Apr 1, 2004 | 06:34 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I am sure the tool mentioned is a good one, but I just use an apprpriate C clamp
:seeya
:steering:
Old Apr 1, 2004 | 07:40 PM
ittlfly's Avatar
ittlfly
Default Re: Need help with mounting rear calipers (jackdaroofer)
:iagree: Be sure to remove some of the brake fluid from the master cylinder before pushing the piston back into the bore. You'll be in for a nasty suprise if you don't. :D .... or just open the bleeder a little to give the fluid some place to go.
[Modified by ittlfly, 4:41 PM 4/1/2004]
Old Apr 1, 2004 | 08:09 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Need help with mounting rear calipers (ittlfly)
: .... or just open the bleeder a little to give the fluid some place to go.
:iagree: But close the bleeder as soon as the piston is compressed...otherwise you might forget to do it :D
:seeya
:steering:
Old Apr 1, 2004 | 09:12 PM
ittlfly's Avatar
ittlfly
Hey Jack,
(Not to hi-jack the thread), but where the hell have you been? I miss poking fun at you. :D
Old Apr 1, 2004 | 09:54 PM
CaliforniaVette
thanks guys, i was sure thats what i had to do so i went down to sears and bought the craftsmen Pad Spreader.
Old Apr 2, 2004 | 06:42 AM
Brimis's Avatar
Brimis
Bleed the brakes when your finished.
[Modified by Brimis, 6:42 AM 4/2/2004]
Old Apr 2, 2004 | 11:47 AM
CaliforniaVette
Default Re: Need help with mounting rear calipers (Brimis)
yea :thumbs:
Old Apr 2, 2004 | 07:51 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Hey Jack,
(Not to hi-jack the thread), but where the hell have you been? SNIP:D
:rolleyes: I was asked by homeland security to stay off the internet until they could determine if the Aly Kida group had hijacked my screen name and could possibly be using it to communicate with dissident vette owners from other internet sites! Having done my civic duty, I am back :D
:D
:seeya
:steering:
To Need help with mounting rear calipers
