Engine AND Trans Removal-'85 4 + 3
I dropped my tranny from below, so I can't help you there.
TTT
I had the fron of my car on ramps and the rest of the car on 3 ton stands with the bottom frame 16" from the ground,. the headers go in and out with ease,,, but the car needs to be higher if you want to pull the tranny cause,, with the tranny sitting on a tranny jack it is higher,,, thus the need for I believe 20" of frame to ground clearance.
