MPG is crazy... Any suggestions?
Old Apr 2, 2004 | 10:22 AM
VB Black Ice's Avatar
VB Black Ice
Default MPG is crazy... Any suggestions?
Well, here's the down-low. I think I have some sort of sensor issue or something... Currently I'm getting 13.9 MPG on my vette and I can't figure out why. My setup is as follows: Mini Ram, 52mm throttle body, 24# injectors, LT headers, HF cats, Flowmasters. I should be getting better than this. My chip is corrected to accomidate for the increase in fuel from the injectors. Whenever I reset the computer I get about 17-19 mpg for a little while and then it starts to dwindle. When it gets in the low 14s or lower it has a hard time starting. I've replaced the following: fuel pump, FPR, fuel filter, and O2 sensor. Any answers?!
Old Apr 2, 2004 | 10:25 AM
rick lambert's Avatar
rick lambert
Default Re: MPG is crazy... Any suggestions? (VB Black Ice)
Not throwing any codes? My guess would have been 02, maybe you should check it. :seeya
Old Apr 2, 2004 | 10:33 AM
VB Black Ice
Default Re: MPG is crazy... Any suggestions? (rick lambert)
I'm thinking its the chip I got from TPiS. When I replaced the O2 sensor (less than a week ago) it cleared up for a while and now its back...
To MPG is crazy... Any suggestions?
