Need Electrical Help
Old Apr 2, 2004 | 07:15 PM
Dilweed's Avatar
Dilweed
Default Need Electrical Help
Took my '86 in to get the carpet put in and weatherstripping on. Started to put the interior back together, and noticed a problem. The interior lights do not work on delay or when the door is open. The hatch release on neither door works, but the one in the console works. The lights above the door handles work when you push them, but not when door is open. The halo lights come when the hatch is open. I checked all fuses and looked at the wiring diagram, can't see anything obvious. Thought I'd quite for the day, have a beer, and ask for help. Don't really want to put everything together until I figure it out, may need to get to the wiring. Any and all help will be appreciated.
Rich
P.S. The door panels had to come off to do the weatherstripping, something in a panel?
Old Apr 2, 2004 | 08:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Need Electrical Help (Dilweed)
That would be my advice; I bet they foregot a connection or two.
Old Apr 2, 2004 | 10:09 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Make sure they didn't tape the door jam switches closed.
Old Apr 3, 2004 | 12:21 AM
jfb's Avatar
jfb
The people that installed your carpet and weatherstripping unplugged a connector and didn't put it back. Take it to them and have them correct their mistake!
Old Apr 3, 2004 | 01:23 AM
olman's Avatar
olman
Default Re: Need Electrical Help (jfb)
If the doors are left open too long it burns up the delay switch. It is located taped to the wiring above and behind the ECM on the right side of the car. This part is no longer made. Search the archives to find ways to fix or bypass this switch. I have tried to repair mine (85) but won't know the results till I get the engine back in. I used radio shack part #276-1778 that solders into the switch circut board. I"ll post the results when I get the car back together. Don't hold your breath :nonod:
Old Apr 3, 2004 | 12:43 PM
Dilweed's Avatar
Dilweed
That sounds like it. Had the doors open for quite a while when doing the door panels. Exactly what does that part look like? When you say behind the ECM, is that toward the back or front of the car? Will try to find a search of archives, but not sure how to do that. Thanks.
Rich
Old Apr 4, 2004 | 12:58 AM
olman's Avatar
olman
Rich: the switch is, per service manual, "behind RH side of IP (instrument panel) taped to IP harness". Mine is black in color, about two inches square and three quarters of an inch thick, it has a tab on one end with a hole in it for screw mounting. It was taped with masking tape. Came from the factory with that kind of high tech fastener! The high end Buick, Olds and Pontiac of the same year also used this switch. You might try wrecking yards. :cheers:
Old Apr 4, 2004 | 04:37 PM
chonko66's Avatar
chonko66
Default Re: Need Electrical Help (olman)
Hey, I have the same problem with my '85.... How do I get behind the IP?
Remove radio???
Jim... :confused:
Old Apr 4, 2004 | 07:07 PM
BIG JIM 54's Avatar
BIG JIM 54
Default Re: Need Electrical Help (chonko66)
The ECM on early C4 anyway, is under the carpeted panel on the passenger side. As soon as you get that panel off, you'll see a cadnium-plated box pushed up verticle into the dash with a bunch of wires going to it. That's the ECM. The two screws that hold it up in the dash are easy to get to and you should have no trouble finding what you are looking for once the ECM is down.
BIG JIM
To Need Electrical Help
