91 vette custom prom
Old Apr 3, 2004 | 02:39 PM
6spd's Avatar
6spd
Default 91 vette custom prom
i have a 91 vette timing at 6 degrees. i found false knock retard at 3000 rpms, my headers were hitting frame. so then i had jesse ski down it burn me a prom and improve my knock retard, but it is the same as before i have. the ezlink scanner. before i had the prom done i disconnected the knock senser then hooked it back up but never disconnected the battary so it has a stored code could this be the reason?? do i have to reset everything with the new prom. this problem is really starting to **** me off everything is new from wires, fuel pump,cap rotor,all ignition things are done. the only thing that is left is a slipping balancer???? :rant: :rant: :rant: :rant:
Old Apr 3, 2004 | 04:48 PM
6spd's Avatar
6spd
Default Re: 91 vette custom prom (6spd)
anyone??
