88 coupe posi unit?
Old Apr 3, 2004 | 10:05 PM
Metamando's Avatar
Metamando
Default 88 coupe posi unit?
Does anyone know who built it, how to find one, where to get parts for rebuild, or ANYTHING??? Mine is sounding pretty bad, I thought I had a broken spring or something, but I've been told its the posi. I can't find any info anywhere, or any for sale......please help
TIA
:seeya
[Modified by Metamando, 4:02 AM 4/4/2004]
Old Apr 3, 2004 | 10:22 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: 88 coupe posi unit? (Metamando)
:cheers: If you want to go for the whole pumpin, ecklers, mad or lots of others sell them
If you just want the gears, check Richmond Gear1
:seeya
:steering:
Old Apr 3, 2004 | 11:17 PM
Metamando's Avatar
Metamando
Default Re: 88 coupe posi unit? (jackdaroofer)
thanks Jack........tried Richmond, didn't see anything specific about my car......will try the others
:seeya
Old Apr 3, 2004 | 11:28 PM
vader86's Avatar
vader86
Its a standard Dana 36 rear, slightly different setup because of the independent rear, but you should be able to find it easily.
Old Apr 3, 2004 | 11:36 PM
Metamando's Avatar
Metamando
Default Re: 88 coupe posi unit? (vader86)
thx Vader, but my mechanic (a vette specialist) told me the 88 is different from 89 and 87........according to him, I have to find one in a junkyard. I just can't believe with so many cars still on the road, that no one is making rebuild kits. Checked Ecklers and MAM, no luck so far. I'll keep trying.......
:seeya
Old Apr 3, 2004 | 11:38 PM
vader86's Avatar
vader86
:skep: Just what did he tell you was different about it?
Old Apr 4, 2004 | 12:53 AM
rodj's Avatar
rodj
Only 2 rearends in C4s.
Dana 36 in autos and Dana 44 in manuals
Old Apr 4, 2004 | 09:57 AM
Metamando's Avatar
Metamando
He said that because of the way the suspention ties into it, it was specific to an 88 vette, Im not sure if he meant the whole differential or just the posi unit. Im really quite clueless here, as you can see. Thanx for your help.
:seeya
Old Apr 4, 2004 | 10:27 AM
vader86's Avatar
vader86
There is nothing different about the actual rear, and all 88-96 have the same rear suspension setup.
Your mechanic doesnt know what he's talking about.
Old Apr 4, 2004 | 08:03 PM
Pete K's Avatar
Pete K
In the past I have bought all my rear parts from Toms diff"s I don't have the address or phone number handy it has been a couple years. Very fast service and good pricing. Most or all of the rear guts are still available direct from gmbut you will pay plenty.
Old Apr 4, 2004 | 08:46 PM
CFI-EFI's Avatar
CFI-EFI
First: Are you sure it is bad? Has the "posi traction" action gone away? I got a rude awakening a long time ago when a mechanic cured my popping and snapping posi traction, by changing the gear grease.
Second: According to my Dana (it is a Dana rear end you're dealing with) parts book, the diff case and internals (posi unit) are the same from 1985 - 1991. That's all the later my book goes.
It really frosts me when an "expert" says he knows, when he doesn't. There is no shame in looking something up. Maybe you two were speaking of different items? Or you misunderstood him?
Look in the phone book, under "truck parts", and look for the Spicer or Dana logo. Ask them if they handle Spicer axle parts. Good luck, and...
RACE ON!!!
Old Apr 4, 2004 | 10:46 PM
corvette1990's Avatar
corvette1990
Default Re: 88 coupe posi unit? (CFI-EFI)
Go to page 22 for parts and rebuild parts like I just did. Then call them. http://www.ring-pinion.com/docs/randpcat.pdf or call up TPIS for a new rear http://www.tpis.com/CatalogPages/CatalogPage.asp or exotic muscle http://www.exoticmuscle.com/webpage....SEL=DRIVETRAIN Personally, I would get a second opinion and get gear lube changed first. It is truley expensive what your considering.
To 88 coupe posi unit?
