Having problems with opening driver door lock...Please help if u can!!
Old Apr 4, 2004 | 11:18 AM
88BlackZ-51's Avatar
88BlackZ-51
Default Having problems with opening driver door lock...Please help if u can!!
Sometimes that door will open, and sometimes it will not! Seems like it is trying to catch on something, and when it does it opens. Not a big deal, but sometimes a little embarassing.
Any ideas what the problem is???
Old Apr 4, 2004 | 02:07 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
Default Re: Having problems with opening driver door lock...Please help if u can!! (88BlackZ-51)
1. Make sure it is level with the door jam. 2. Spray the heck out of it with some lube, WD40, etc. good luck . :flag
Old Apr 4, 2004 | 02:08 PM
greenvette95
St. Jude Donor '03
1. Make sure it(door) is level with the door jam. 2. Spray the heck out of it with some lube, WD40, etc. good luck . :flag
Old Apr 4, 2004 | 05:41 PM
88BlackZ-51
Default Re: Having problems with opening driver door lock...Please help if u can!! (greenvette95)
will try
Old Apr 5, 2004 | 05:12 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
DON'T use wd40.
Get some real stuff from a locksmith shop. They have lock cylinder lube that will suck right into the lock (capilary action) and lube it properly. WD40 is a quick fix, and will just attract more dirt and grime.
To Having problems with opening driver door lock...Please help if u can!!
