half shaft R&R proceedure?
Old Apr 4, 2004 | 11:32 AM
dwestsr's Avatar
dwestsr
Default half shaft R&R proceedure?
I tried a search but came up empty. I'm sure this has been posted many times, but can you tell me the best way to remove and install the Half shafts in an 86 coupe? I've got a loose ujoint and I need to replace them all. If you can include the drive shaft , It you help. Thanks :cheers:
Old Apr 4, 2004 | 02:53 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: half shaft R&R proceedure? (dwestsr)
CF member scorp508 has created an excellent how-to document on this:
http://personal.tmlp.com/scorp/vette...nts/index.html
Old Apr 4, 2004 | 05:05 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Re: half shaft R&R proceedure? (tobijohn)
:iagree:
Old Apr 4, 2004 | 06:58 PM
dwestsr's Avatar
dwestsr
Thanks a bunch. That is exactly what I needed. Couldn't ask for better instuctions. :cheers:
Old Apr 5, 2004 | 04:05 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Leave the camber bolt alone. Take the bolt off the other, the one connected to the knuckle. That way you don't need to worry about keeping track of the alignment marks.
When jacking up the spring, slide the floor jack in from the wheel side and not the rear of the car. Put a towel on the jack to protect the spring. Put the jack pad in just past the spring nut right on the spring. Keep in mind it may not feel like the spring is pushing down hard, but there is alot of force pushing down.
[Modified by ConeKLR, 4:13 PM 4/5/2004]
Old Apr 5, 2004 | 04:11 PM
scorp508's Avatar
scorp508
Default Re: half shaft R&R proceedure? (ConeKLR)
If you do it the way I show you it is just as easy. Taking the knuckle bolt out CAN be a huge pain. If you look inside the knuckle there are 3 small bumps of metal protruding into the knuckle which can destroy the threads on the bolt if you are not careful and do not have the knuckle and rod aligned properly.
Six in one half dozen in the other.
Old Apr 5, 2004 | 06:37 PM
89vert's Avatar
89vert
:iagree: I just did my axle shaft u-joints this weekend. Just use a 3/8 socket extension to line the hole back up. I also found it much easier to get to the differential strap bolts with about 2' of socket extensions from outside the wheel well. Hope this helps
To half shaft R&R proceedure?
