Head/Cam TPI - Need Input
Old Apr 4, 2004 | 09:56 PM
Vic'89's Avatar
Vic'89
Default Head/Cam TPI - Need Input
I'd like some feedback on anyone running a Heads and Cam TPI combo.
What Aftermarket Heads or Cam are you running ?
Any Track times or Dyno sheet would be helpfull.
Vic
Old Apr 4, 2004 | 10:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Head/Cam TPI - Need Input (Vic'89)
Vic, check out that "Result of L98 mods" page on my site. The table is taken from an old mag. article with similar mods to a '90 L98. You will notice that Vette was not as quick as yours with similar mods...maybe the gears...and it was a 6-speed???
The just ported & worked the #113s and tried two TPIS cams but it will give some idea of what to expect. I can see you gaining about 50-60chp with your intended mods, after they're tuned in of course.
Lets see what contemporary info comes in here.
Old Apr 4, 2004 | 10:37 PM
ZD1's Avatar
ZD1
I HAD a 224/230 on 112 Compcams and ported fastburn heads. I had a real pita because the had a lot of dynamic vacuum between 1500 and 4500 at part throttle so I was running realy lean. Even thogh I compensated with a custom chip and more fuel...all I did was run lean (>17) at part throttle and rich (<12). I was running a SDPC base and the stock runners. The heads flowed about 265 CFM, and the whole inuduction path flowed (gulp) 198 CFM!
Basically, my idea of a high speed tuned system worked, but before I could tune it. I know run a MRIII with same duration 114 deg sep and MORE LIFT!
Old Apr 5, 2004 | 02:12 PM
Vic'89's Avatar
Vic'89
Any more input ?
There has to be more guys running aftermarket Heads/Cam on a TPI.
Vic
Old Apr 5, 2004 | 03:15 PM
Red Tornado's Avatar
Red Tornado
I agree, there has to be tons here. You know my setup (see April '04 mods in my sig), but its yet to happen since I'm waiting on the heads. I should have it all installed in a few weeks. Sorry I can't be of any use at the moment, I wish I could :(
edit: I think that eventually you and I will be in about the same boat in terms of mods.
[Modified by bradvette, 3:16 PM 4/5/2004]
Old Apr 5, 2004 | 05:25 PM
1MoorTym's Avatar
1MoorTym
I basically have the same upper end as you. I went with a ZZ4 cam because its a perfect match to the 113 heads which I didn't plan on changing. You could probably go with a ZZ9 (maybe a little larger) before the stock heads and the rest of the intake are an issue. I don't have any numbers at the moment, but just put a custom chip in and plan to take it the VetteDoctors to dyno as soon as it stops raining - if ever.......
Old Apr 5, 2004 | 07:43 PM
redfast's Avatar
redfast
Default Re: Head/Cam TPI - Need Input (1MoorTym)
I have a ported Accell base, ported D-113, LPE 119 cam@.560" lift ported slp runners and plenum. Alot of people are running this combo into the low 12s :thumbs:
Old Apr 5, 2004 | 08:00 PM
Vic'89's Avatar
Vic'89
Default Re: Head/Cam TPI - Need Input (redfast)
Do you have a superram or TPI ?
I dont see any examples of low 12 second TPI Vettes.
Vic
Old Apr 5, 2004 | 08:04 PM
dtorc4's Avatar
dtorc4
See sig. I have no clue what I'm going to run at the track though (if I can ever get out to it). :banghead: It feels really strong though.
To Head/Cam TPI - Need Input
