Broke the Temp Sensor During Header Installation?
Apr 5, 2004 | 10:00 AM
I broke the plastic connector on the sensor on the driver's side head between the #1 & #3 cylinders. Is this the coolant sensor or what?
Apr 5, 2004 | 10:04 AM
Re: Broke the Temp Sensor During Header Installation? (geezel)
yea, I think it is...
Apr 5, 2004 | 10:54 AM
GM swapped the position of the gauge sending unit and the fan switch several times. On your 1986, that should be the aux fan switch.
RACE ON!!!
Apr 5, 2004 | 11:57 AM
Re: Broke the Temp Sensor During Header Installation? (CFI-EFI)
How would I know for sure? Could the dealer tell me or should I just pull the old part & look for a part number?
Apr 5, 2004 | 12:28 PM
Cruise-In II Veteran
It's your aux fan sensor for sure; there should be a Grn/Wht wire attached.
The ECM sensor is under the middle of the TB and the gauge sensor is below #6 & #8.
There is a pic in the new MAM catalog on pp. 4.45.
Apr 5, 2004 | 12:31 PM
Re: Broke the Temp Sensor During Header Installation? (65Z01)
O K... Thanks!
Apr 5, 2004 | 12:38 PM
I said, "
should ", only because one never knows what has been done to a 19 year old car. According to my GM, Corvette, parts book, it
IS !
RACE ON!!!
Apr 5, 2004 | 12:49 PM
If it has a spade connector it is the temp guage sensor. If it has a mushroom shaped connector it is the aux fan switch.
Apr 5, 2004 | 01:22 PM
Re: Broke the Temp Sensor During Header Installation? (Bluevette85)
It's a mushroom-shaped connector.
Apr 5, 2004 | 01:59 PM
Fan switch then. I busted mine too. I just shove the pin into the sensor and keep an eye on it. :)
Apr 5, 2004 | 06:51 PM
Napa has replacement connectors.
