Fuel Rail pressure test valve core source???
Old Apr 5, 2004 | 04:27 PM
Topless87's Avatar
Topless87
Default Fuel Rail pressure test valve core source???
I have an 85 which I remove the nitrus from. But, the prev owner removed the valve core from the schrader valve. Does anyone know a source to get a replacement core thats OK for a gasoline environment?
Also, for now, is a 4AN fitting cap enough to run with or is it too much of a safety risk?
Old Apr 5, 2004 | 08:17 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Fuel Rail pressure test valve core source??? (Topless87)
My 1984 came with no easy way to check fuel pressure. I spliced a tee into my fuel line and installed a tire valve assembly into the tee. I would expect a tire valve stem core would work for you.
RACE ON!!!
Old Apr 5, 2004 | 09:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm running a tire valve core in the Schraeder on my '88 Vette and it's worked well for over a year now.
An A/C line valve cap will work on the Schraeder too.
[Modified by 65Z01, 9:39 PM 4/5/2004]
Old Apr 5, 2004 | 09:44 PM
VetteNoob's Avatar
VetteNoob
I think I still have mine from when I installed my FP gauge. You're welcome to it. You can also get ones made for A/C valves and it would be fine. I suppose the ones for tires are ok too.
To Fuel Rail pressure test valve core source???
