Speedo wrong
Old Apr 6, 2004 | 06:59 PM
davber's Avatar
davber
Cruising
Default Speedo wrong
Hi All,
I'm new to the Vette community. I just got a 91 Coupe, 6speed and I'm working through some of the issues it has to get it road worthy. It apparently has a new speed sensor but the speedo is way off. I haven't done any extensive testing but it appears to be off by 10 to 20mph (low). The car was originally an automatic. I'm not sure that this is important but I thought I'd mention it just in case. Can anyone give me a clue on what to look for in diagnosing the problem?
Thanks in advance,
Dave
Old Apr 6, 2004 | 07:27 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Speedo wrong (davber)
Welcome to the forum.
It sounds like the proper speedo gears for your rear axle ratio weren't swapped in when the trans was changed.
RACE ON!!!
Old Apr 6, 2004 | 07:31 PM
davber's Avatar
davber
Cruising
Default Re: Speedo wrong (CFI-EFI)
That sounds plausable. Can you be more specific? I thought that these cars used a speed sensor that runs off of the front wheel for the speedo. Where would be gear you're refering to be? I've got a chiltons manual but it's basically useless.....
Dave.
Old Apr 6, 2004 | 07:53 PM
corvette1990's Avatar
corvette1990
The speedometer is NOT run off a wheel sensor. It is run off a set of small plastic gears in the transmission. The Automatics have a different rear gear usually something like 2.59 or the performance (like I got is 3.07). The 6 speed trans usually has around 3.45 rear gears. Then the rear tires also make a difference too. You should have 275-17 inch tires stock. Check those as well. You can have a transmission shop or do it yourself, change the gears to match the rear. see this website for example of gears available. http://www.exoticmuscle.com/webpage....EL=DRIVETRAIN. You could also get an electronic box to change the ratio for the speedo as well. Hope this helps, chris :flag
Old Apr 6, 2004 | 10:19 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Default Re: Speedo wrong (corvette1990)
How does a smaller tie size affect the reading? Instead of 275's, what if they're 235's??
To Speedo wrong
