Muffler Eliminators?
Old Apr 6, 2004 | 08:58 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Muffler Eliminators?
Mid America has a set of muffler eliminator pipes for $130. has anyone installed these? How did it sound, and did it give you a performance boost?
Old Apr 6, 2004 | 09:02 PM
ffvetteman's Avatar
ffvetteman
Default Re: Muffler Eliminators? (ir0nmaiden420)
I have them. They sound great!!
Listen to someone elses before you buy. Some people think they are too loud. But they are perfect for me!!
Old Apr 6, 2004 | 09:28 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
You won't see any performance gain, but you willlove the sound, check it here:
inside the car
http://temp.corvetteforum.net/c4/mrm...ovspanuzzo.wmv
outside the car
http://temp.corvetteforum.net/c4/mrm...oburnci2-1.wmv
varying RPM's
http://temp.corvetteforum.net/c4/mrm...lspinslide.wmv
at idle
http://temp.corvetteforum.net/c4/mrm...cameratest.wmv
First 20 seconds here give you a good idea
http://temp.corvetteforum.net/c4/mrmojo2//rt211u1a.wmv
Windows open
http://temp.corvetteforum.net/c4/mrmojo2//rt211up.wmv
Old Apr 6, 2004 | 09:34 PM
ir0nmaiden420
Default Re: Muffler Eliminators? (Mr Mojo)
[QUOTE]You won't see any performance gain, but you willlove the sound, check it here:
Why no performance gain? I would think it would give more boost than a muffler, since nothing is blocking the airflow?
1985vette's Avatar
1985vette
i heard elims actually hurt performance, due to loss of backpressure? is that true? I thought that the cat and the resonator provided enough back pressure
Old Apr 6, 2004 | 09:56 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Muffler Eliminators? (1985vette)
:yesnod: You won't notice it, but you will lose some power, I lost 1.5 mph in the 1/4 mile.
Old Apr 6, 2004 | 11:08 PM
GREENNV's Avatar
GREENNV
I love mine. It took about an hour to install myself.
I run a 13.5 with a 2.3 60' with them. I can't see losing any power from it, I dynoed at 307 rwhp and 311 ftlb of torque when it was 102 outside. :auto:
Old Apr 6, 2004 | 11:22 PM
VAHROOM's Avatar
VAHROOM
What I did was go to a local muffler shop. I asked him to remove the stock mufflers and make a straight pipe to take their place. He was done in about an hour and charged me 80 hoops. I was able to select the tips I wanted and select the height and extension I wanted.
Check around and you may find a similar deal. I didn't even get my hands dirty.
Old Apr 6, 2004 | 11:23 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Muffler Eliminators? (GREENNV)
Trust me you will lose some power, I have several hundred timeslips to back up my claim.
I went from 108 mph to 106 mph, that's a loss. My et's got better, but mostly due to me getting better with the car.
12.97@106 with eliminators or 13.07@108 with full exhaust. MPH was higher with full exhaust.
Old Apr 6, 2004 | 11:36 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Default Re: Muffler Eliminators? (VAHROOM)
:iagree:
It cost me $30 - I had it done at Midas - yeh, can you belive it.
I had them install a straight pipe where the muffler was and reweld the stock tips back into place. Sound is not that loud , but sounds great too - I can't see spending $1K on a cat-back system until I have a lot of dough to blow
Old Apr 7, 2004 | 11:14 AM
KTA1000's Avatar
KTA1000
Is the loss of power with the LT1 or L98, I was considering these for my L98. I thought a CAt back system was a good way to gain power, wouldnt the eliminators have a similar effect by reducing back preasure ? I'm just looking for answeres before I buy something.
Paul
Old Apr 8, 2004 | 04:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On an L98 you won't notice much power difference; the rest of the exhaust system is so restrictive.
To feel the power boost, install a 2 1/2" front Y, hi-flow cat and muffler elims; you can expect about 15-20chp gain and you will see the increase in your time slips. Of course you need to add an AFPR so you can bump fuel pressure to match fuel flow to the increased air flow at WOT.
The bottom line with an L98 (at least with the D-port heads) is that you do not need back pressure (D-ports minimize reversion and cam overlap isn't large enough to blow through the charge with no back pressure) if you properly tune the engine; remember it's a system.
Old Apr 8, 2004 | 06:27 PM
Strick's Avatar
Strick
I helped a friend install his Corsa catback on his 94 and he gave me his stock exhaust which I installed elims on. I have this exhaust on my 92 LT1, pretty much stock, and the sound is great. Now I sound like one of the guys at the shows. Some day, I'll buy the B&B catback which sounds just right for my purposes. But for now, I love these elims. :thumbs:
Old Apr 8, 2004 | 10:29 PM
VAHROOM's Avatar
VAHROOM
Default Re: Muffler Eliminators? (KTA1000)
I applied these to my 90 which was a L-98, I personally noticed more of a power band shift rather than a power loss. It had a little less lower end torque but a little more upper end. I measured almost 7 more HP on my rolling dyno. It wasn't enough to feel but it did seem to run better. In all fairness the main reason I did it was there was a rattle in the left muffler that drove me nuts. It had to go. SO......
To Muffler Eliminators?
