ECM and Security
Old Apr 7, 2004 | 10:20 AM
Ozman's Avatar
Ozman
Default ECM and Security
Apparently I have activated the Vehicle Anti-Theft System when I changed the ECM in my 93 Vette. The car does not turn over and the security and SYS lights flash a couple of times. The Service ASR and battery light stay on in the information center.
Is there a way to correct this? In other words, to defeat the VATS?
Old Apr 7, 2004 | 10:43 AM
rick lambert's Avatar
rick lambert
Default Re: ECM and Security (Ozman)
Have you tried disconnecting your battery for a few minutes to reset codes? ;) Did you replace the Prom? some of these problems occur if the prom is not seated well-OR installed backwards, have you read any codes? :confused:
Old Apr 7, 2004 | 12:04 PM
Ozman's Avatar
Ozman
Default Re: ECM and Security (rick lambert)
Yes, I disconnected the negative terminal. I don't know if disconnecting the battery altogether will reset anything. I used the same stock prom and made sure it was installed correctly. I have not read any codes yet.
To ECM and Security
