BFG Drag radials - a different question.
Old Apr 7, 2004 | 06:38 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default BFG Drag radials - a different question.
Just mounted mine. I was curious what air pressure you guys like when you are driving on them - either daily or to and from the track.
Old Apr 7, 2004 | 07:19 PM
AS84's Avatar
AS84
Default Re: BFG Drag radials - a different question. (LT-4 CE)
I ran my 275-40-17's at 22 psi on the street and 18 on the track. I had perfect tire wear, decent traction, and never had a problem on tire pressure sensor clearance.
On my 325-60-15's (different car) I run 12-14 psi depending on track conditions.
Old Apr 7, 2004 | 07:22 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: BFG Drag radials - a different question. (AS84)
I drive mine on the street at 30psi, then when I'm at the track, I lower them to 18psi. Of course, I only drive them on the street when I have business to attend to. ;)
Old Apr 7, 2004 | 08:07 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Has anyone tried the new M/T ET Street RADIALS? They come in 275/40-17, and are supposedly very sticky!
Old Apr 7, 2004 | 08:17 PM
CFI-EFI's Avatar
CFI-EFI
I run my P255/50R16s at 32 pounds on the street. At the track I run them at 32 pounds. Whaaaat! Hey, it's a Crossfire.
RACE ON!!!
Old Apr 7, 2004 | 08:25 PM
LT-4 CE's Avatar
LT-4 CE
Default Re: BFG Drag radials - a different question. (POLOVETTE 94)
Accorging to Jeg's they are not available unitl June-ish. Hot Rod just compared them to regular slicks of same size on an 11 second Nova and got BETTER 60' WITH THE RADIALS.
Old Apr 7, 2004 | 08:28 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I run 32 psi on the street and at the track, 21-22. BFG doesn't recommend going below 15 psi.
Old Apr 8, 2004 | 05:23 PM
Corvette0096's Avatar
Corvette0096
30 Hiway and 18 at the track.
Old Apr 8, 2004 | 07:52 PM
LT-4 CE's Avatar
LT-4 CE
275/40/17 DR's are almost .75" wider than my 275/40/17 SZ50s.
Old Apr 8, 2004 | 11:11 PM
AS84's Avatar
AS84
Default Re: BFG Drag radials - a different question. (Mr Mojo)
They'll suggest it if you're running 5.7 1/8 miles on them :yesnod:
To BFG Drag radials - a different question.
