Suggestions for 85 Vette Engine Performance Rebuilding
Old Apr 7, 2004 | 09:14 PM
jchavez's Avatar
jchavez
5th Gear
Default Suggestions for 85 Vette Engine Performance Rebuilding
I am looking for suggestions to rebuild a semi-stock 85 Vette. Currently, the following mods/add-ons have been made:
a. Exhaust - Flowmaster Cat-Back - Custom Coated Headers
b. MSD-8875 Ignition
c. Large Tube Engine Runners
d. Rocker Arms
i. Replaced Valve Seals
e. Jet Performance Speed Chip
f. Performance Pulley Set
g. Fast Pack . Throttle body -Fuel Pressure Regulator
h. Modified Open Air Filter
i. Modified MAF Sensor
i. Big Mouth Manifold
j. Ported Plenium
Old Apr 8, 2004 | 04:18 PM
dtorc4's Avatar
dtorc4
Default Re: Suggestions for 85 Vette Engine Performance Rebuilding (jchavez)
One question:
How much money do you want to spend?
First thing should be heads and cam. If you have some serious dinero to spend, stroke it, slap a miniram or superram on it, high stall torque converter, maybe change ther rear end gears.
Old Apr 8, 2004 | 04:37 PM
MrNuke's Avatar
MrNuke
Everyone mentioned good paths to take.
With your mods, IF you have a Z51 '85 you should be in the mid to high 13's already.
If you add long-tube headers, it'll make everything flow even better. As someone already asked, it all comes on how much you want to spend.
I went with a superram intake setup, and new heads on top of all the little 'tricks' and bolt-ons out there.. Car runs great.
Old Apr 8, 2004 | 07:58 PM
85vet's Avatar
85vet
Cruise-In V Veteran
All I can say is - Stroke it! Stroke it! Stroke it! :yesnod:
Stroker = 383 just in case you are not sure what I am talking about.
Do some searches on 383 or stroker to see what are some proven setups.
Good Luck.
Old Apr 8, 2004 | 08:51 PM
NitrousSam's Avatar
NitrousSam
You may want to consider a replacing the heads and replace the cam and lifters.
To Suggestions for 85 Vette Engine Performance Rebuilding
