Fan Switch Question
Old Apr 8, 2004 | 06:00 PM
NavyVet's Avatar
NavyVet
Default Fan Switch Question
My Helms is at a friend's house - can't get it for few days. I removed the A/C (all underhood components - need to keep interior ducts, etc for class legality) and now the radiator cooling fan is running all the time. Can anyone tell me which wire to cut (i.e., install a toggle switch in so I can force it on if I need it?
Thanks a lot. Paul :flag
[Modified by NavyVet, 4:01 PM 4/8/2004]
Old Apr 8, 2004 | 06:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Fan Switch Question (NavyVet)
Locate the connector that was plugged into A/C pressure switch in the coolant line; it has a Grn wire and jumper that connector or twist the two wires together and tape them.
With that connector open (the switch is a NC configruation) the ECM sees the A/C pressure too high and brings on the main fan.
Indeed you can install a SPST switch between the Grn wire and ground to have manual fan control when the engine is running.
[Modified by 65Z01, 6:20 PM 4/8/2004]
Old Apr 8, 2004 | 06:48 PM
NavyVet's Avatar
NavyVet
Default Re: Fan Switch Question (65Z01)
65Z01 - is that the two-wire (black & dark green) switch on the tubing running down into the bottom of the firewall box for the heat exchanger? BTW, it runs when the A/C system is set ot "off." I will try the jumper tonight when I get home if that's the right switch. Thanks a lot. Paul
To Fan Switch Question
